  3. Warnings in schematic
  • Subscribers 166
  • Views 12961
praveen24
praveen24 over 10 years ago
Hi all,
I am getting below warnings, while creating the net list from the or-cad capture
#1 WARNING(ORCAP-36006): Part Name "CAP_0.1UF_X5R_6.3V_20% 0201 _SMD0201_0.1UF" is renamed to "CAP_0.1UF_X5R_6.3V_20% 0201 _SM".
#2 WARNING(ORCAP-36006): Part Name "CAP_10UF_Y5V_10V_10%_0805_SMD0603_10UF" is renamed to "CAP_10UF_Y5V_10V_10%_0805_SMD06".
#3 WARNING(ORCAP-36006): Part Name "CONN_HDMI_TYPED_1_XHDMI_A121901_19PIN_MALE_XHDMI-A121901" is renamed to "CONN_HDMI_TYPED_1_XHDMI_A121901".
and etc,..
How to overcome those warnings
  • Snowman7
    Snowman7 over 10 years ago
    Hi Praveen. Mark *.dsn File, go to Tools > Create Netlist >PCB Editor > Setup. You will find by Miscellaneous "Device/Net/Pin Name Char Limit. Increase the number in this field to prevent the warning.
  • praveen24
    Thank u J.Snowman.. I did that meanwhile time now i am facing the issue which was layout file (Pcb editior)not accepting the footprint to import. It showing file name was too long.
