  3. Problem with viewing output of Pspice Simulation of Mixed...
  • Views 15286
Problem with viewing output of Pspice Simulation of Mixed Signal Design
AllaboutDesign
AllaboutDesign over 11 years ago
I am trying to simulate a mixed signal circuit. I can measure the output of analog components, but cannot measure output for digital components. I have inserted a sample below. Vo_sch1 is the output of schmitt trigger whereas Vout is the output of analog circuit (which acts as an input for the schmitt trigger).
Please advise how to view both analog and digital outputs in mixed signal circuit.
RL
  • oldmouldy
    oldmouldy over 11 years ago
    Digital signals in PSpice are shown as "state", 0 1 X Z and so on, Analog signals are shown as voltages. You can add an analog component, like a resistor, to the digital net and it will change from "state" to a voltage.
  • AllaboutDesign
    Thanks! Yes indeed that was the issue.
    Now it is fixed.
    Appreciate your help.
