  3. Error in Netlist: Multiple pin ...
  • Views 22245
Hossein1357
Hossein1357 over 11 years ago
I am trying to use Bus pin capability for creating schematic symbols in OrCAD 16.6 like below picture:
and connected bus from FPGA to it in schematic like below:
However, it fails during netlist creation and I receive mass of errors like below:
#1 ERROR(ORCAP-36036): Multiple pin [25..27]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
Check for incorrect packaging of all devices in U1.
#2 ERROR(ORCAP-36036): Multiple pin [25..27]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#3 ERROR(ORCAP-36036): Multiple pin [25..27]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#4 ERROR(ORCAP-36036): Multiple pin [31..39]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#5 ERROR(ORCAP-36036): Multiple pin [31..39]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#6 ERROR(ORCAP-36036): Multiple pin [31..39]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54)
#7 ERROR(ORCAP-36036): Multiple pin [31..39]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#8 ERROR(ORCAP-36036): Multiple pin [31..39]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#9 ERROR(ORCAP-36036): Multiple pin [31..39]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#10 ERROR(ORCAP-36036): Multiple pin [31..39]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#11 ERROR(ORCAP-36036): Multiple pin [31..39]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#12 ERROR(ORCAP-36036): Multiple pin [31..39]'s which have differe
#13 ERROR(ORCAP-36036): Multiple pin [42..44]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#14 ERROR(ORCAP-36036): Multiple pin [42..44]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#15 ERROR(ORCAP-36036): Multiple pin [42..44]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#16 ERROR(ORCAP-36036): Multiple pin [52..54]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#17 ERROR(ORCAP-36036): Multiple pin [52..54]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#18
#19 ERROR(ORCAP-36036): Multiple pin [49..50]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#20 ERROR(ORCAP-36036): Multiple pin [49..50]'s which have different nets connected for U1: SCHEMATIC1, 01-DDS (203.20, 2.54).
#21 ERROR(ORCAP-36018): Aborting Netlisting... Please correct the above errors and retry.
I really appreciate any help in this regard,
Hossein
  • oldmouldy
    oldmouldy over 11 years ago
    You cannot use bus pins on primitive parts, see page 291 of the Capture Users Guide, cap_ug.pdf, in the doc\cap_ug directory of the installation.
  • Hossein1357
    Sorry, there is something else in mentioned page. I couldn't realize its relation to my issue. I am using OrCAD 16.6, did you reference the same revision?
    Anyway, Why can't I place bus pins in my symbol when its available in symbol editor?
    What else can I do to get rid of placing bunch of pins instead of a bus? Is there a workaround?
    Hossein
  • oldmouldy
    16.6 version Page 291 has a discussion on Bus Connectivity: "You can use bus pins...." then: "Bus pins will only work with the VHDL netlist format. No other netlist format understands them.
    Do not use bus pins in the following situations:
    Pins on primitive parts.
    Any design that you intend to use with PCB Editor." There is no workaround, part pins need to be scalar, individual pins.
  • Hossein1357
    Thank you for the answer. Yes, It seems so.
    However, in my document it is on P245 not P291!.
    I found it by searching the exact phrase you had written. Is there any new update for document? I would appreciate if you can give me a link.
    Thanks again,
    Hossein
