  3. Creating a board outline made of multiple line segments
  • Subscribers 167
  • Views 16185
D Campbell
D Campbell over 10 years ago
Hello everyone,
I'm pretty new to OrCAD and PCB design so this is probably pretty simple.  I have a board outline that is made of multiple line segments and curves.  I want to use the 'Z-Copy Shape' Command to create a package keepin that is slightly smaller than the board outline.  When I attempt this I get this error 'Not a closed polygon or CLine. Element ignored!'  Which makes sense because it was made up of multiple line segments and maybe that causes a problem.  I chamfered all the corners just to make sure they were connected but that didn't seem to fix it.  The line segments do not have a break in them and the polygon they form is enclosed.
Is there a way to have OrCAD recognize this as an enclosed shape or some other way to accomplish this?
Thank you!  If any other information would be useful please let me know.
I am using 16.3.
  • redwire
    redwire over 10 years ago
    Yes. Use the "Shape->Compose Shape" menu item. Z-copies need to be closed shapes. Not a fan of lines for board outline but a lot of beginners use this method.
  • D Campbell
    Thank you!  That was exactly what I needed.
    What would be the better way to make board outlines?
  • docb
    docb over 10 years ago
    I have that same question about what to make outlines, if not lines. The PCB wizard makes outline as lines.
  • SevenFortyOneB
    SevenFortyOneB over 10 years ago
    I like to create the initial outline using lines, especially for complex board shapes where I import a .DXF file, and then turn it into a shape as mentioned above. Then, I'll decompose the shape back into lines again. This ensures I have a clean, contiguous, outline but allows me to increase the width of the line a little for visual purposes.
