  3. Assigning copper pour to a net
  • Views 17895
D Campbell
D Campbell over 11 years ago
Hello all,
I have another pretty simple question.  I want to fill the top layer of my board with copper pour.  The way I tried to do it was I took the board outline and did a Z-Copy and contracted the board outline a little and made that dynamic copper.  This works perfectly but the copper is not assigned to any net.  I can't seem to figure out how to assign this to a net.  I'm sure it's simple but I can't seem to find where to do this.  The options menu doesn't have the net field like it does when you're creating the pour from a shape.
Hopefully that made sense.
Thank you!
  • Wild
    Wild over 11 years ago
    I believe the best way is to use the Edit -> Split plane approach. Easy fast and it remembers the net you attach it to if you need to regenerate it.
  • D Campbell
    Yep that worked. Thank you!
  • redwire
    redwire over 11 years ago
    You can assign during the z copy as well.  Before right.mouse->done just select down to "Assign net" in the right mouse menu.
    Also you can "Shape->Select Shape".  The options menu will allow you to change or select the net you want to assign to.
  • D Campbell
    Thank you!  That's the method I tried at first but I was missing the select shape part.
  • steve
    steve over 11 years ago
    If your using the latest version you can right click - Customise - Enable Shape selection through Shape Fill then hover over the fill of the shape and use right click - Assign Net. No need to use Shape - Select Shape or Void any more...
