  3. Circular Shape PCB Board
  • Subscribers 167
  • Views 14217
Deep7086
Deep7086 over 10 years ago
How do I create a circular shaped board outline with a fixed radius. I don't see an option for circular/elliptical shape in setup--> outline--> board outline.
Any help is appreciated.
Cheers
Savy
  • Deep7086
    I figured out. Thanks anyway.
  • redwire
    redwire over 10 years ago
    Just for others then who might look this thread up and wonder....
    Add->Circle
    then using Options window select Active Class->Board Geometry, Subclass Outline
    Click at desired center of circle. Then in the command window click and type "ix <radius>" where <radius> is a value in the board units (mils, mm, inches, etc...) of the radius of the circle.
    Other methods include just moving the mouse to the desired location; using the Coordinates entry box.
  • steve
    steve over 10 years ago
    To add to what redwire has said, there are also settings in the Options fold out menu to set the radius, center + radius etc
  • Deep7086
    Thanks Redwire
