  3. unable to add vias on one side of the board
  • Subscribers 166
  • Views 14313
segera
segera over 10 years ago
Hi all, i am trying to design a multilayer PCB board.i have routed a large extent of the board but when i am at my final routing stages i am unable to add vias by double-clicking.When i try adding vias, my PCB editor  goes busy and is unable to respond.I am using allegro PCB editor version 16.5.How do i solve this please.
Regards
  • steve
    steve over 10 years ago
    Check to make sure your running the latest 16.5 Hotfix, also check Constraint Manager - Physical Rules and vialist's and also routing allowed on that layer...
  • segera
    thanks steve...the latest 16.5 hotfix...you mean the latest version of the software or soething else
  • steve
    Go to Help - About there is a code - Cadence issue hotfixes (software patches) approx. once every two weeks. These include new features as well as bug fixes. If your code is 16.5-p00 something then this is the base release (first issued version) so I would recommend getting the latest hotfix for 16.5 from cadence or your channel partner and trying again. You could also look at the other suggestions I made if you can't access this.
  • segera
    my code is 16.5P003 dated 4/29/2011...i am now downloading 05 May 2014 ADW16.50.042, Version: ADW:Hotfix:16.50.042~wint ...will install it thanks
  • segera
    sorry i mean Version: SPB:Hotfix:16.50.062~wint thanks
