  3. Converting .dat files to csdf
  • Views 13660
DylanColaco
DylanColaco over 10 years ago
Hi All,
I would like to know if there is a simple way to convert binary .dat files produced by AMS Simulator to .csdf or .txt format. (Perhaps a command line utility)
This would allow us to use python to process multiple simulation result files to automate various measurements.
The current workaround is enabling .PROBE/CSDF. However the problem with this is method is that AMS Simulator does not display waveforms while the simulation is running, so the engineer will not be able to visually observe incorrect results, if any, until the simulation is complete(which may take a few hours in some cases).
