  3. Strange routing problem
  • Subscribers 166
  • Views 14244
Grubi
Grubi over 10 years ago
It happens suddenly - every attempt to connect or route finish with track that has no net (Null Net and Line to SMD spacing error). It also want to start route  from specific layer (in my case layer 5), even I am selected Top layer.
I try few things, check constraint manager, grids, route options, updating netlist, dehighlight all - but with no success. Since I am saving regular copies on every step, and older copy before few hours works normally, but current design just driving me nuts.
Any ideas? I am running version 16.6 s050 - I new there is hotfixes available, but just want to know if it is something I just enable by mistake.
  • Grubi
    Today I was able to re-create the problem again - when routing it just start suddenly not on pin or via I want (anymore), but slightly shifted and of course without net, which leads to error. Otherwise it is starting on wanted layer. No change in mode or dehilight all was able to fix the problem. I think it is kind of bus, or at least something that I don't have answer for.
    Well, it is very annoying and it is good that I save often. Any ideas?
  • steve
    steve over 10 years ago
    Check your Find Filter (fold out menu on the right hand side) and make sure that Pins and Vias are enabled, otherwise you can't route from these items. Also have a read of http://community.cadence.com/cadence_blogs_8/b/pcb/archive/2015/07/22/what-39-s-good-about-allegro-pcb-editor-disable-of-open-space-routing-16-6-has-it which talks about disabling routing in "blank space".
