  3. Exporting library from old design files
  • Subscribers 166
  • Views 19466
stantheman286
stantheman286 over 10 years ago
Hi everyone,
I've been searching on this forum and others, and so far haven't found an exact answer to my issue and I'd really appreciate your input.  I'm coming back to OrCAD after a few years with other tools, and even then I was a relative newbie, so my knowledge in this area is fairly limited.
What I want to do is take our previous design files (.dsn and .brd) and dump the parts data into a library (.olb) and symbols files (.dra, .psm, etc).  Ideally, I'd like to upload these parts into our CIS database to use with data downloaded from CIP, but for now a local library is my first goal.
I have exported an .olb from my old .dsn file by copying the design cache to a new library and saving it.  I then exported the part symbols from the .brd file using Export > Libraries.  I updated psmpath and padpath to point to the symbols directories I exported the part data.  I also updated my capture.ini for both the library and symbol locations:
[Allegro Footprints]
Dir0=C:\git\new_design\Symbols\Board1
Dir1=C:\git\new_design\Symbols\Board2
Dir2=C:\Cadence\SPB_16.6\share\pcb\pcb_lib\symbols
Dir3=C:\EMA\CIP-E\Allegro_Library\symbols
[Part Library Directories]
Dir0=C:\git\new_design\Libraries
Dir1=C:\EMA\CIP-E\Schematic_Symbols
When a create a new design and add the new library I've created, I'm noticing that when try Show Footprint on a number of the parts I've placed from the new library, that I get the "Allegro footprint <PART> was not found in the search path" error message.  However, in the old design file, if I place parts from the design cache (not my new library), the part previews show up when I click Show Footprint.
The old design files were copied from our previous designer's machine, and therefore the paths in the design cache and symbols information are incorrect, which I thought might be the issue.  Do I need to run a Replace Cache on the old .dsn and point it to my new library before exporting again?  Do I need to run a Place > Update Symbols before exporting from the old .brd file?
Thanks!
Matt
  • stantheman286
    Ok, I think I'm getting a bit farther.  I've discovered that the if I rename the .psm and .dra files of the offending devices to what the schematic is expecting, the Show Footprint command works.  I also was able to export a netlist without any warnings about missing footprints.  However, this doesn't answer why this issue is occurring.  I tried to back annotate from the PCB design hoping that would fix the incorrect symbol names, but it didn't.
    Here's a quick example of one device:
    Schematic is looking for: BLE_MOD
    Exported symbol files: BLE.dra, BLE.psm, BLE_BLE_BLE.txt
    Renaming the first two files to BLE_MOD.* resolves the schematic issues, but it seems like a workaround and not an actual fix.
    Thoughts?
    Thanks!
    Matt
  • oldmouldy
    oldmouldy over 10 years ago
    Because the value in the PCB Footprint property is the name of the Package Symbol that "Show Footprint" is trying to open. IF the PCB Footprint value is BLE_MOD, then the files BLE_MOD.dra and BLE_MOD.psm are going to have to be found in the Footprint search directories, otherwise the Footprint won't be shown. IF you changed the PCB Footprint value to BLE, then your original filenames would have worked. The footprints used are controlled by the schematic so you cannot back annotate the values from the PCB.
  • stantheman286
    Ah, yes thanks for explaining that.  I was able to go in and modify all my symbols that were pointing to the wrong footprint.  It looks like everything is resolved now, I'm getting the footprints when I view them in Capture and they're placing correctly in PCB Editor.
    Thanks!
    Matt
