  3. How to measure Net Etch Length considering vias in vertical...
  • Views 24268
How to measure Net Etch Length considering vias in vertical direction using Allegro?
momo1982
momo1982 over 10 years ago
Hi all,
I found that Allegro can't measure net length with via height between the routing layers, which is illustrated in following figures. These two connections actually have a difference of (board thickness * 2), but allegro seems just measure the length in horizontal directions, ignoring the height coming from via.
Total etch length 316 mil here:
Total etch length still 316 mil here. But actually there is a (2*Board Thickness) here which should be considered.
Is there any method in allegro that we can get the REAL net length including the trace length, and via height between the routing layers?
Thanks so much!
  • oldmouldy
    oldmouldy over 10 years ago
    See this post: community.cadence.com/cadence_technology_forums/f/27/t/32420 you are going to need a license for the Allegro High Speed Option to include the via "height" in length calculations.
  • momo1982
    Hi,Thanks for classification! What should I do to the license for Allegro High Speed Option ? Do I need to buy it?
  • oldmouldy
    You would need a license for Allegro PCB Designer and then you could add the High Speed Option license to that, obviously, the Via Z-length isn't the only feature that you get since the High Speed Option enables a large array of High Speed Rules and Routing capabilities. Appearances can be deceptive but, from the portion of the board shown in the screenshot, it looks like it would be hard to justify the cost of these licenses for the design that you have.
  • momo1982
    Hi, My company already had several Allegro PCB designer licenses, including Professional, L (Legacy), and Performance L. I still can't use the High Speed Option? The High Speed Option is a separate license? Btw, the post you shared said"The Z Axis delay is part of the High Speed Option which bolts onto Allegro PCB Designer", but where? I checked my constraint manager, doesn't get any clue. Thanks~
  • redwire
    redwire over 10 years ago
    I believe that option is in the user setup menu as one of the options not in constraint manager iirc.
