  3. Allegro PCB 16.6 funckey show/hide subclasses
  • Views 2440
KSielewicz
KSielewicz over 10 years ago
I want to create a shortcut that will allow to show or hide layers that are visible. For example I press "x" and then Package Geometry / Silkscreen TOP appears and I press "z" and this layer hides. Any idea how can I do that?
Thank you in advance,
Krzysztof
  • Randy R
    Randy R over 10 years ago
    You could set up a couple of scripts to replay and assign them to keys.  One problem with using x & z is you will need to enter a carriage return.  If you use a couple function keys or control-x/control-z to avoid needing the carriage return.  Below are two scripts I recorded for turning Package Geometry/Silkscreen_Top On/Off.  Save them in two separate text files *.scr and then alias the keys you want to use to replay them; i.e. alias F5 replay "PackGeomOn.scr"  and alias F6 replay "PackGeomOff.scr".
    Turn On:
    color192
    setwindow cvf.dialog
    cvf layer_mode
    cvf layer_tree_item 'Package Geometry'
    cvf layers_visible package_geometry/silkscreen_top TRUE
    cvf okay
    setwindow pcb
    Turn Off:
    color192
    cvf layer_mode
    cvf layers_visible package_geometry/silkscreen_top FALSE
    cvf okay
    setwindow pcb
  • fxffxf
    fxffxf over 10 years ago
    try the following:
    funckey x color -vis "PACKAGE GEOMETRY/SILKSCREEN_TOP"
    funckey z color -invis "PACKAGE GEOMETRY/SILKSCREEN_TOP"
    You can also toggle visibility of a layer by using "-toggle" instead of -vis  -- This way you only need to define a single key.
    The color command has a number of options. To see them, on the Allegro command line do:
        color -help
  • KSielewicz
    Thank you for your comments!
