  3. DRA - Adding Via in pad
  • Replies 12
  • Views 7456
Wild
Wild over 10 years ago
Version: 16.6 S.053 (Latest Hotfix)
Editing a footprint trying to add a via in pad. --------------------NOTE this is a DRA file---------------------------
Issue: No available via
Tried adding a via to the Default PCS, however this Constraint Set does not show up in the CM.
Attempted to add a secondary PCS - never shows up.
Work around:  Exported the CS from 16.5 with the via I wanted in the PCS then imported the CS into 16.6 footprint.  The via now shows up, however it is in the Dsn Via field.
Is this a bug or am I missing something?
  • Wild
    It solved the issue.
    Now I have 2 registry hacks I need to remember:
    1 for Capture when it crashes
    2. One for Allegro when the CM goes wacky.
    Thanks for being around Oldmouldy, have learn alot from watch your post's over the years.
  • Wild
