  3. How to make a slot into a PCB
  • Views 22605
alvjorge
alvjorge over 11 years ago
designing a daughter board in which a slot is needed to make an slot to save large components on the main board.
The daughter board has a dimensions of 5x5mm and the daughter board need a slot of 1x1mm.
Starting the design, I placed the board outline, route keepin... and for not having troubles in future routing, I would like to add the hole now.
How can I draw/place this slot?
  • Do I need to draw a board outline shape inside the current shape?
  • Do I need to create a new layer with different parameters?
  • Would it be better to define a new padstack with slot dimensions, and then a mechanical symbol with this padstack?
If there is another better way to perform this action, it would be welcome.
KR!
  • admin
    admin over 11 years ago
    Thanks for your help
