  3. How to make a slot into a PCB
  • Views 22604
alvjorge
alvjorge over 11 years ago
designing a daughter board in which a slot is needed to make an slot to save large components on the main board.
The daughter board has a dimensions of 5x5mm and the daughter board need a slot of 1x1mm.
Starting the design, I placed the board outline, route keepin... and for not having troubles in future routing, I would like to add the hole now.
How can I draw/place this slot?
  • Do I need to draw a board outline shape inside the current shape?
  • Do I need to create a new layer with different parameters?
  • Would it be better to define a new padstack with slot dimensions, and then a mechanical symbol with this padstack?
If there is another better way to perform this action, it would be welcome.
KR!
  • steve
    steve over 11 years ago
    Best to use a Mechanical Symbol with a slot defined as the padstack. That way you can add keepout areas etc to the symbol and then output the slot info using NC Route.
  • alvjorge
    Thanks Steve! I have no use NC Route tool before, so is it an automatic tool or should I configure some parameters for slot info?
  • redwire
    redwire over 11 years ago
    Simple. Just draw a line of the correct (desired) width on the Board Geometry:Ncroute_Path sublayer.  When you run Manufacture->NC->NC Route it will build the appropriate route control file that can be sent to the fabricator.  Be sure to use Enhanced Excellon mode.
  • steve
    Take a look at:- http://www.parallel-systems.co.uk/images/PDF/slots_pcb_editor.pdf
  • alvjorge
    Done!
    Thanks again Steve!
