  3. Windows 10 - anyone, anyone?
  • Subscribers 168
  • Views 4119
redwire
redwire over 10 years ago
Just curious if anyone has tried Allegro/Capture on Win 10 yet and what their experience was?  How about min recommendations for a new laptop? I am really wanting to get onboard with W10 but fear that I will be navigating this alone for a while... Feedback appreciated.
  • steve
    steve over 10 years ago
    We have been running Allegro on Windows 10 (pre-version) for a couple of weeks and have not seen any issues. It's not officially supported yet but I believe Cadence are looking at it. In our experience performance is much better than Windows 8.
  • mnitesh
    mnitesh over 10 years ago
    I am unable to run Allegro 16.3 on Windows 10 Pro. It takes a long time to start and then gets stuck as in not responding.
    Can you suggest any fix ?
  • oldmouldy
    oldmouldy over 10 years ago
    You could try setting the Application compatibility to Windows 7 but, since Windows 8 needed 16.6 to run correctly, it's likely that you will need to upgrade to 16.6-2015 to run on Windows 10 and that does seem to be fine as far as Capture (CIS), PCB Editor and PSpice are concerned. Since 16.6 is the only available version at present, Cadence are unlikely to announce support for any past versions once they have completed compliance testing for 16.6-2015.
  • swapu
    swapu over 6 years ago
    So it looks the latest Allegro physical viewer 17-2_v100318 has a problem where the arrow keys don't work for panning around the layout (on both Windows 10 and Windows 7). I had to revert back to 17-2_v041117 and arrow keys starting working fine again. Took me hours to figure out this stupid SW bug. Hope it helps someone!
