  3. Re-Display reference designator
  • Subscribers 166
  • Views 14550
Grubi
Grubi over 10 years ago
If deleted for any reason, reference designator (for example on ASSY_TOP and/or SILK_TOP) can reapear if component is unplaced and placed again.
Is there another way to display again deleted reference designator without unplace-place operation?
Thanks.
  • stump1019
    stump1019 over 10 years ago
    A refresh of the symbol will work also.
  • Grubi
    Thanks!
    Place-Update Symbols - Refresh
  • padmaster
    padmaster over 10 years ago
    Using the Place-Update Symbols command will refresh all footprints. You can go into "placementedit" mode, then hover the mouse over a particular part, then right mouse click over the part and select "refresh symbol instance". This will update that particular part only.
