  3. variant editor won't see my DNI components
  • Views 3695
saipan59
saipan59 over 10 years ago
I am trying to use Variant Editor to make a DNI BOM report, as per our organization's process. I open Variant Editor, do a New Variant, fill in the four fields, click OK. My new variant appears in the left pane, with sub-folders of Components and Functions.
The problem is that the Components folder is empty - it does not populate with my DNI components as I expect it to.
I have an older project which works fine doing the same thing. I've checked every setting and dialog that I can think of that might possibly be related, but I can't find a difference. The newer project just doesn't work. I opened the various dialogs side-by-side, looking for a setting that is different, but found nothing different except the name.
Another hint: When I run Packager / Bill of Materials, select Variant BOM, and view the output, at the end of the file is "DNI Component List:", but the list is empty. On the older project, my DNI parts show up in the file as expected.
What could be set incorrectly in the project?
I'm running 16.6-S013 (v16-6-112AL), dated 7/1/2013 .
Thanks for any advice,
Pete
  • saipan59
    FYI, I've logged a ticket with Cadence Support, and got a prompt response. I'll report back with any resolution. -Pete
  • saipan59
    UPDATE:
    [This makes reference to a small test project that I was using for experiments.]
    With some experimenting, and talking to folks on another project, I just discovered this:
    The Variant Editor has a problem with using a part attribute named "VARIANT". In my project, DNI parts are identified with an attribute of VARIANT, and a value of DNI.
    As an experiment, I changed R701 and R728 attributes to be BOM_IGNORE=DNI, instead of VARIANT=DNI.
    In Variant Editor, select View / Customize Columns.
    Note that it allows you to add columns for various things, including BOM_IGNORE and VARIANT and others.
    *** But when I click Apply, the VARIANT column does not display. ***   The BOM_IGNORE column works as expected.
    Note that "VARIANT" is an option in the drop-down, and it lets you move it to the right-side box by clicking the right arrow, but it ignores it when try to display it.
    With the BOM_IGNORE column visible, I can now see the parts that have the BOM_IGNORE=DNI property (in this case, R701 and R728, which I manually changed). This makes it easy to select them as a group, and set them to be "DNI".
    SO, I think this allows me to move forward, knowing that using "VARIANT=DNI" is a problem.
    Pete
