  3. Error while Importing DX Designer tel file to Allegro
  • Subscribers 163
  • Views 15917
mgohil
mgohil over 10 years ago
Hello, I have designed the schematics in DX Designer. Netlist is generated with 0 Error and it also generate the device file.  But what I observed device file device type did not show up in .tel netlist file.
So below error is coming while importing
! '705-3215-260' ! '100k' ; R467
ERROR(SPMHNI-67): Cannot find device file for '705-3215-260'.
Also .net file does not have PCB Footprint property.
Another error of .tel file is exclamation,
ERROR(SPMHNI-62): Expected '!' before device, line ignored.
! '288-0970-020' ! 'BEAD' ; Z16 Z17
I have attached .tel and resistor device file. Can any one has face ever thins kind problem regarding this ? or how to modify the Allegro config file to generate .tel netlist having PCB library
.tel file
$PACKAGES
 ! '351-6804-610' ! 'TPS53316RGTT' ;  U46 U45 U47
 ! '351-3114-010' ! '2308' ;  U31
 ! '913-3348-080' ! '1uF' ;  C155 C161 C148 C151 C156 C158 C147 C153 C160,
device file
(Device file for RES-H)
CLASS IC
PINCOUNT 2
PINORDER RES-H M P
PINUSE RES-H BI BI
FUNCTION G1 RES-H 2 1
PACKAGEPROP VALUE VALUE
END
  • Mstrghettorigg
    Mstrghettorigg over 10 years ago
    Do you have DEVICE and PKG_TYPE field assigned on the schematic symbol?
  • Mstrghettorigg
