  3. Dimensions disappear when associated feature changes layer...
  • Subscribers 166
  • Views 12865
Allan M
Allan M over 10 years ago
Dear Allegro Developers,
Edited:
I am not looking for a solution here; this is more of a bug report.
Say a board file conatins a linear dimension measuring a symbol feature such as a rectangle. If you change the layer of the feature in the symbol file and refresh the symbol in the board file, the associated dimension disappears.  I have to redraw the dimension all over again.
Why can't the dimension follow the feature it is measuring?  The loss of the dimension element seems like a bug to me or, at least, a very undesirable feature.
Allan Macdonald
  • steve
    steve over 10 years ago
    The forum is not the best place for this. Go to Cadence Online Support (or the Channel Partner you bought the software from) and file a case for R & D to look at this - but with that being said I've just tried this and say I have a shape on Board Geometry / Soldermask_Top that is dimensioned I can hover over the shape and change it to Board Geometry / Silkscreen_Top and the dimension stays where it is. What version of software are you running ?
  • Allan M
    Thanks for your kind advice, Steve.  For what it's worth, I updated the post to better describe the problem; the problem happens when I change the feature's layer in the symbol and then update the symbols in the board file.  Nevertheless, our vendor is EMA Design Automation; I will contact them about this issue.  My apologies to all if this posting was inappropriate
    Allan
