  3. Roam by grid unit, not screen/other pixel
  • Subscribers 166
  • Views 909
Vikas Dabas
Vikas Dabas over 10 years ago
When i look into env file, i learned that arrow key are used to roam around board based on pixel(most probably screen)
Can you help me to roam around based on grid unit.
Some times we need to move components on grid, i need to roam using arrow keys but on grid. it is random to roam based on pixel.
Vikas Dabas
  • steve
    steve over 10 years ago
    Have no active command and then select the part (so it highlights) then use the SHIFT+Arrow Keys to move the part based on grid. Remember the Active class / subclass affect which grid you are on. If it's Etch/TOP then it uses the Etch grid, if it's Package Geometry / Some subclass then it uses the Non-Etch Grid.
  • Vikas Dabas
    Thanks bro. i got it.
  • Vikas Dabas
    Sorry for waking the thread,
    But while moving a block of component using "move" it flikers the screen and it moves wrong side. It comes to default position and than move one unit.
    than when pressed right key, it comes to default position and moves one unit. is there anything that it moves as single component.
