  3. Dimensioning Text Block #
  • Subscribers 163
  • Views 14450
Lennie
Lennie over 10 years ago
For existing Dimension text how do you determine the text block number ? And how can you change it.
  • TiBo
    TiBo over 10 years ago
    Go to Dimensioning Parameters: Text block and enter your desire text block number
  • Lennie
    Thanks. Unfortunately that does not change the block size on existing text. Also I am not sure that is the block size for currently existing text.
  • TiBo
    If you want to change what is already there, go to Instance Parameters and set the text block.
