  3. Component Placement Side
  • Views 14616
purikku22
purikku22 over 10 years ago
Hi!
I just want to know if there is a way to attached a property to a symbol its placement side in Allegro?
e.g. LED should be on A-side only. If placed in B-side, a DRC error will be flag.
Thank you and regards,
Eric
  • Soundman99
    Soundman99 over 10 years ago
    you should be able to do this through Rooms.  I don't know if there's a better way to do it, but check out the documentation on the Room property, and then add a room to just the A-side or B-side of the board.
  • mcatramb91
    mcatramb91 over 10 years ago
    You can use the ALT_SYMBOLS property to drive the placement side.  The ALT_SYMBOLS property will allow you to define different alternate symbols for placement on the design.  You can also specify different component symbol by layer.  If you just define a symbol from the BOTTOM layer and apply the ALT_SYMBOL_HARD Property as well it will automatically mirror to the Bottom side during placement.
    Here is an example of the how it could be done in a Device File
    PACKAGEPROP ALT_SYMBOLS '(BOTTOM:0603RF_WV_12D)'
    PACKAGEPROP ALT_SYMBOLS_HARD
    This states that on the BOTTOM Layer the component symbol "603RF_WV_12D" is used but it doesn't specify a symbol for the TOP Layer. NOTE: The ALT_SYMBOLS_HARD Property is required to force it to the values defined by the ALT_SYMBOLS.
    Unfortunately, this needs to be defined in the Schematic and driven during import logic and cannot be added directly into Allegro.
    Not sure of the schematic package you are using so please consult the documentation to determine how it should be applied on the schematic side.  Just search for ALT_SYMBOLS in the Allegro documentation for details.
    Hope this helps,
    Mike Catrambone
  • purikku22
    Thank you for your reply.
    Its a little bothersome to set. haha
    I hope cadence can simplify the procedure, just by adding the option in the Constraint manager Component section.
    Eric
