  3. Centering diff_pairs
  • Views 13235
Les Wong
Les Wong over 10 years ago
Hi All:
Does anyone have a good way to center diff_pair between connector pins ?
I have tried the gloss routine, no luck.
Les
  • mcatramb91
    mcatramb91 over 10 years ago
    Hi Les,
    You can use "spread between voids" (Route > Resize/Respace > Spread Between Voids) for centering between pins.    It works on diff pairs and single ended nets as well.  Just start the command, select the active subclass to perform the centering and select two pins to define the channel.  You also define the extra spacing to the plane void from the Options Tab.
    Hope this helps,
    Mike Catrambone
  • Les Wong
    Thanks Mike, we wish you could window around trace segments to be centered.
  • iCraig
    iCraig over 10 years ago
    Les,
    File a service request (create a case) for this. I've file one earlier this year to be able to select just 2 points. The more people that ask the better chance it will be implemented.
    Craig
  • Les Wong
    Will do, thks
