  3. How to use RotateSilkAssyRD.il skill file
  • Views 15030
Vikas Dabas
Vikas Dabas over 10 years ago
Hi i have downloaded latest file RotateSilkAssyRD.il. it is V2.2.
Now when i tried to load the file, i use this along with nsware code:
Data of "allegro.ilinit"
; load the nsWare framework and products
load("./RotateSilkAssyRD.il")
load("./nsWare/nsware.il" "nsware" )
it loads only nsware in toolbar. how do i use the silkscreen script? please elaborate.
thanks.
  • KoryMJ
    KoryMJ over 10 years ago
    Hello.
    The RotateSilkAssyRD Skill script does not load into the menus.  You run it by entering "rotate_silkassy" at the Allegro command line (no quotes).
  • redwire
    redwire over 10 years ago
    That code was taken without approval from the author. The person who posted it stripped the author's name. You should not be using it. Sorry, I won't help with this!
  • Vikas Dabas
    Hey Redwire,
    Please don't get me wrong, you helped Mr. Dipak Desai
    Date 15 Jun 2012 2:55 PM
    Don't the instructions give you a different command?
    From the file:
    ;#  Usage:  rotate_silkassy (from within Allegro)                          #
    Try typing that command at the command line instead.
    Why???? if it is so.
    thread was:How to start a Skill file from Allegro command line
    Refference from thread: Silk Rotate skill file
    is this script written by Mr. "eDave"?
    he had created different version of this script.
    if not than who is the real author?
  • eDave
    eDave over 10 years ago
    I didn't write the original. The code (with the author's details apparently stripped) was posted in January 2011 and a few of us innocently helped to get it working. It has taken on its own life since then.
    It is difficult to prevent people doing this which is one reason that I post some code in a context form.
