  3. same net via spacing
  • Views 14848
Lock2002
Lock2002 over 10 years ago
Is it possible to set a maximum via to via overlap allowed? I have a bunch of vias that are used in thermal tabs and some of the via pads are overlapping. I don't want shut the DRCs off because I would like to keep the via hole to hole controlled.
  • SevenFortyOneB
    SevenFortyOneB over 10 years ago
    I don't know if there is an overlap seting that can be applied, but perhaps modifying the via padstacks to make the pads smaller would work.  You'd then have to remember to use a cline or a shape on other layers to take the place of the pads to support the holes.
