  3. Modify thermal relief on single pin
  • Views 15875
D Campbell
D Campbell over 10 years ago
Hello all,
I have a pretty simple problem that I can't get the right search terms to be able to google.
I need to delete one of the connections on thermal relief but I can't seem to do it.
To clarify, here is a picture of the thermal relief and trace going by it.  I would like to delete the south connection so the trace can pass by without intersecting.
Hopefully this isn't too difficult.
Thank you!
  • B Bruekers
    B Bruekers over 10 years ago
    Goto the edit menu -> Properties.
    Then set the find filter only to 'Pins'
    Then click on a pin an you see a Edit property box.
    There  you can select one or more DYN_*  items, and adjust the property.
    Like, DYN_THERMAL_CON_TYPE = DIAGONAL
