  3. Connecting SMD pin pad to GND copper plane
  • Subscribers 166
  • Views 15769
Jrigbi
Jrigbi over 10 years ago
I have all the components placed and routed on the board. Now for mechanical mounting purpose I have two SMD pin pad on the bottom layer(its 2 layer board). Now I'm supposed to connect this pin to GND plane (copper pour) using full contact. I searched through the forum and found few option to try but they didnt work. I have following questions.
- My mechanical pin is not assigned to any net name, so does that means I can not connect it to GND copper pour?
- Is there a way to assign a net name to SMD pin, if it doesnt not exist in the schematic?
  • docb
    docb over 10 years ago
    If its got an actual pin/pad for a heat sink, I'd assign it a real pin in the schematic.
  • redwire
    redwire over 10 years ago
    Allegro is a netlist driven tool.  For that reason if you want to connect a pin to a net then it needs to be in the netlist.
    There are tricks that some may offer but let's start with the basics.
  • techk
    techk over 10 years ago
    One thing you can do is define the SMD pin as a via in the physical constraint set. Then you can connect the pin as you would a via.
