  3. DRC not flagging line to hole clearance violation
  • Views 13572
Allan M
Allan M over 10 years ago
Hello Cadence Community,
I have a weird problem.  I have a board with two mechanical symbols, each with an unplated mechanical pin padstack.  If I route a line through one hole, I get a DRC error while if I route the line through the other hole, I do not get a DRC error.  This is very strange.  I cannot find out what the difference is between these two holes.  Perhaps someone can look at my board to see what the problem is.  Many thanks in advance.
I am using OrCAD PCB Designer, 16.6.
Cheers,
Allan
p.s.  How the heck do you attach a file?  I'd like to post a zip file of the project.  I will try posting "media" so here goes!
clearance_bug.zip
  • techk
    techk over 10 years ago
    On smallhole, edit the pad and turn off "Mech pins use antipads as Route Keepout" .
  • Allan M
    Thanks Dan! I knew it was something subtle! The funny thing about that solution is that I do not have any anti-pad defined for that padstack. You would think the software would ignore the option unless there was actually an anti-pad defined. Cheers, Allan
