  3. Database Setup
  • Views 13474
Database Setup
DanGSIE
DanGSIE over 10 years ago
I tried setting up a database and I am receiving Error(ORCIS-6273): Unhandled Exception.
How do I setup the database properly?
At one point when I was linking the configuration file to the new MDB file the software complained that there are no tables present.
Thanks.
  • steve
    steve over 10 years ago
    Take a look at:- http://www.parallel-systems.co.uk/images/PDF/access_odbc.pdf and http://www.parallel-systems.co.uk/images/PDF/cis_define_dbc.pdf. The database must also be correct. There a sample one that comes with the tools so take a look at:- <your_install_dir>\tools\capture\samples\BENCH.mdb and make sure your DB is formatted in a similar way.
