  3. Display the length of a class of nets on the fly.
  • Subscribers 167
  • Views 13505
Lennie
Lennie over 9 years ago
In pads they have a spreadsheet the shows the length of traces of a class and the values change on the fly so you can match the lengths . Can this be done in Allegro ?
  • KoryMJ
    KoryMJ over 9 years ago
    Have you used Constraint Manager?  This capability is there.
  • Lennie
    Yes but it looks like you have to run analyze every time. Perhaps I have not used it enough yet. I want to be able to have the constraint manager on one screen and then route or edit a cline and see the length change on the fly. Can you do this in constraint manager ?
  • Randy R
    Randy R over 9 years ago
    Try looking at the Summary Description for the "allegro_etch_length_on" preference under User Preferences and see if that is what you're looking for.
  • redwire
    redwire over 9 years ago
    Mine shows updates between routes in CM. Don't need to update/analyze each time.
  • steve
    steve over 9 years ago
    I think the key here is that if you leave CM open and use the Delay Tune command to add the length the values are updated instantly. Also depending the license you have (OrCAD Professional or higher) you will also see a heads up display on the canvas when you route / slide / delay tune which gives you real time feedback.
