  3. I can't run a simulation, errors occur
  • Subscribers 166
  • Views 4341
Alexandros81
Alexandros81 over 9 years ago
I have downloaded The OrCad\PSpice Lite 16.6. I have done the schematic attached and tried to run the simulation but gives following erros:
INFO(ORCAP-2191): Creating PSpice Netlist
INFO(ORNET-1041): Writing PSpice Flat Netlist C:\Users\Alexandros\Documents\OrCad Projects\E04-04-PSpiceFiles\SCHEMATIC1\SCHEMATIC1.net
WARNING(ORNET-1119): No PSpiceTemplate for Q1, ignoring
ERROR(ORNET-1019): Pin A in template not found on RB
ERROR(ORNET-1019): Pin B in template not found on RB
ERROR(ORNET-1019): Pin A in template not found on RC
ERROR(ORNET-1019): Pin B in template not found on RC
Note: The PSpice icon doesn't appear on the transistor model 2N3053
  • oldmouldy
    oldmouldy over 9 years ago
    You have placed parts from the tools\Capture\library OLB files, for PSpice in Lite mode, only the parts from tools\capture\library\pspice\eval.olb are supported, these parts will have all the necessary properties for simulation with PSpice.
  • Alexandros81
    Anyone knows a part in Lite that is NPN BJT with HFE = 50 with low DC Ic (say a few hundred mA up to an amp) ?
    I was looking in the Transistors library and I found a few but with high DC collector current (like 10A). Do these parts have similar output as with BJT's with small DC collector current(say a few hundred mA up to an amp) ?
    I want to use it for simulation
