  3. non plated mechanical pin no clearance to copper ?
  • Subscribers 162
  • Views 14404
Lennie
Lennie over 10 years ago
I have a footprint with two non plated mechanical pins. It looks like the copper flows to the drill size with no clearance from the drill to the copper . Shouldn;t it be the same as a regular non plated pin that has clearance ?
  • Lennie
    OK, the padstack has mech pins use antipads as route keepouts. Disabled this and the problem solved!
  • Lennie
