  3. Distinguish net names
  • Subscribers 163
  • Views 14786
shangwu
shangwu over 10 years ago
I have 3 ground planes. Say AGND, DGND and PGND. They are meant to be separated entirely, except to only join in them at a single point at where I wanted. However, if I connect them together in the schematic, the rats nets show them to be a single net and any via would connect them unwantedly. How do I distinguish them? I tried separating them in the schematic level, connect each grounds separately in the layout. Once these are done, I connect them together in the schematic and hope I can connect them in PCB Editor, but everything messes up. Does anyone know how to solve this?
Thank you.
  • steve
    steve over 10 years ago
    Yes - you need to create a netshort symbol in the schematic and pcb and that will be your connect point. Look at:- http://www.parallel-systems.co.uk/images/PDF/Netshort_Definition.pdf
  • Wild
    Wild over 10 years ago
    I do exactly what Steve suggested.
    Only issue: The Cam tools our fab houses uses, flag the net short as an unconnected net in the IPC356/Artwork files.  They ask me approve the net error they flag.  We have never have a build issue due to this,  so I consider it not a big deal, just be aware that this may happen.
  • shangwu
    Yah, it works, thanks.
    I wish it would be much simpler.  What I did in the past was to put a static copper and ignore the DRC error.
