  3. Create gerber files
  • Views 16672
Create gerber files
tk1999
tk1999 over 10 years ago
I'm new to PCB and doing my first Project in Orcad 16.6 lite.
I have a circuit with 3 Leds in row and a connector.
I created the pads in paddesigner. Soldermask and pastemask i made the same size.
I created my board and tried to generate gerber files. (rs274x)
Since  I have only one layer, I created the top.art and I added the silkscreen top file. Board outline I added manually, because it isn't listed in the Color Dialog box under manufacturing. This also worked.
My problem now: How do I get the solder mask top gerber file ? Isn't it defined by my pads that i made? When I add the solder mask manually nothing happens. Undefind line width is 0.2 mm
What am I missing? Thanks for any help.
Thomas
  • steve
    steve over 10 years ago
    You need to create a soldermask top film using class/subclasses Board Geometry / Soldermask_Top, Package Geometry / Soldermask_Top, Pin / Soldermask_Top and possibly Via / Soldermask_Top. There's a youtube video showing this:- https://www.youtube.com/watch?v=l6EH3sdLasA. Just as a FYI there is a Board Outline subclass already under Board Geometry / Outline...
  • oldmouldy
    oldmouldy over 10 years ago
    You need to add a new film to Film Control and add Pin / Soldermask Top to it. The easiest way to manage films is to set the display to have just the subclasses required for the film displayed, then, when the new film is added to Film Control, the film contents will match the display "what you see is what you want", if you have created the film(s) with the incorrect contents, you can always set the display for the required film contents and then right-click on the film name in Film Control and take "Match Display".
  • tk1999
    Thank you. It didn't work because I only added the film from board geometry. The film from package geometry was missing.
