  3. Set minimum drill hole size
  • Subscribers 166
  • Views 13015
aricbeaver
aricbeaver over 9 years ago
In PCB Editor, how do you set the minimum drill hole size in the Constraint Manager? I'm looking to create various sets of constraints based on PCB manufacturers.
  • steve
    steve over 9 years ago
    There is no constraint for this in CM. Drill sizes are set when you design the Padstack. You can get this information from a Padstack Definition report or if you just want the minimum look at the Summary Drawing Report.
  • aricbeaver
    It'd be nice if a DRC could be generated. Thanks for the reply!
