  3. How to include a custom report file like Comp_Place.txt...
  • Views 13913
How to include a custom report file like Comp_Place.txt in the Allegro Report menu
TiBo
TiBo over 9 years ago
I am looking for the way to include my custom report file in the Report menu.
TiBo
  • oldmouldy
    oldmouldy over 9 years ago
    You need to use SKILL to generate and the axlReportRegister function within it to add the report to the menu, the SKILL routine will need to be loaded when PCB Editor starts, this is usually done through the allegro.ilinit file.
  • TiBo
    Thanks Oldmouldy,
    Do you know if there is a skill code out there for this?
    If not, could someone help?.
    TiBo
  • Kirti Sikri
    Kirti Sikri over 9 years ago
    Example of registering your own report is given in Allegro Skill document.
    Example From the document is given below. Is that what you were looking for?
    The following registers the report My Hello. The optional keyword in MyReport lets a direct
    call to MyReport generate a report to a fixed name file, helloWorld.rpt. otherwise it takes
    the name from the report dialog box.
    axlReportRegister('MyReport, "XYZ Inc. Hello" "Hello World")
    ; optional keyword allows a you to call MyReport with a nil where
    ; the report file generated will be helloWorld.rpt. Otherwise if
    ; called from report dialog, it will be passed a temporary filename
    procedure( MyReport(@optional (reportName "helloWorld"))
    let( (fp)
         fp = axlDMOpenFile("ALLEGRO_REPORT" reportName "w")
         axlLogHeader(fp "This is my report")
        fprintf(fp, "\nHello World\n")
        close(fp)
        t
    Unregister above report:
    axlReportRegister('MyReport, nil nil)
    Kirti
  • TiBo
    Thank again Kirti.
