  3. Allegro keeps giving me an error message everytime i try...
  • Views 1396
Allegro keeps giving me an error message everytime i try to Place Manually a symbol (6 pin connector con6)...the message says: ""E- (SPMHGE-82): Pin numbers do not match between symbol and component. Run dev_check on device file for more informat
kapp
kapp over 10 years ago
Allegro keeps giving me an error message everytime i try to Place Manually a symbol (con6)...the message says:
Placing J1 / CON6_CONN6_CON6 / CONN6 on Top.
Select elements to place using tree view.
E- (SPMHGE-82): Pin numbers do not match between symbol and component. Run dev_check on device file for more information.
When I try to place the symbol, I can see the outline of the symbol but it does not let me to place due to the above message.
Please, anybody can help?
please reply to this post or to my email
