  3. fabmaster.out
  • Subscribers 163
  • Views 16443
fabmaster.out
FormerMember
FormerMember over 10 years ago
Hello
fabmaster out is looking for COMP_HEIGHT
Where is this assigned ?
Our vendor is complaining because this field in not populated.
Les
  • techk
    techk over 10 years ago
    As far as I know, there is not an Allegro attribute named "COMP_HEIGHT".
    The Fabmaster utility is looking for an attribute that does not exist.
    I have never used a vendor that wanted that attribute. My Fabmaster utility places a blank space in that field.
    You can assign a Package_Height_Max value to a shape on the footprint, but the Fabmaster utility would need to have this attribute added to the report in the "parts.txt" configuration file.
  • FormerMember
    Dan it does show up in the Cadence view file: component_baseview. Where do I find the parts.txt file ?
  • techk
    Les,
    My Fabmaster utility files are on my local C: drive.
    The parts.txt file is under a folder named "config".
    Hope this helps,
    Dan
  • FormerMember
    Are you using the fabmaster.out from the Allegro export menu ?
  • techk
    Fabmaster.zipLes, I am using the stand-alone Fabmaster utility.
    Dan
