  3. Properties attached to drc error RAVEL_MARKER_DESCRIPTION...
  • Views 12862
Properties attached to drc error RAVEL_MARKER_DESCRIPTION = Soldermask and Board Outline Minimum S pacing on Bottom Layer EXTERNAL_DRC_VALUE = 75.0
TiBo
TiBo over 9 years ago
I have this annoy DRC about soldermask spacing. Could anyone help? I just want to get risk of these. Thanks
LISTING: 1 element(s)
           < DRC ERROR >
  Class:           DRC ERROR CLASS
  Subclass:        ALL
  Origin xy:       (2320.029 12.700)
  Constraint:      Externally Determined Violation
  Constraint Set:  Soldermask and Board Outline Minimum Spacing on Bottom Layer
  Constraint Type: EXTERNAL REFERENCE
  Constraint value: 75.0
  Actual value:     71.0
  Element type:    SYMBOL PIN
  Class:           PIN
  location-xy:  (2256.029 12.700)
  Element type:    SHAPE
  Class:           BOARD GEOMETRY
  Subclass:        OUTLINE
  • oldmouldy
    oldmouldy over 9 years ago
    Tools>Database Check, or Check>Database Check for 2015 OrCAD PCB Editor, click the button for Remove external DRCs
  • TiBo
    Thank Oldmouldy,
    Yes, it works.
    TiBO
    I contacted Cadence and here is their response. Just want to share.
    I checked on your DRC part. It is basically NEW RAVEL DFM DRC RULE that has been setup between solder mask and board outline for minimum spacing. The Allegro 16.6-2015 release now has an option to include a list of limited DFM checks that take advantage of the Cadence RAVEL capabilities. The Relational Rules Starter kit requires the license: MSW43U: Cadence® Relational DRC PCB User
    - To trace the DRC, launch Constraint Manager and go to DRC spreadsheet and last item is "External".
    - Search for Solder mask to board outline spacing DRC - right click and choose "select and show element" - this will take you to the layout where you see DRC
    For more information on RAVEL rule check, please use following links.
    Allegro Relational Rules Checker Starter Kit http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:TechPubDocs;src=pubs;q=/spbPN/spbPN16.6-2015/readme_product_noteQIR009.html
    Allegro Relational Rule Developer: Ravel Tutorial http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:TechPubDocs;src=pubs;q=ravel_tut/ravel_tut2.26/ravel_tutTOC.html
    Allegro Relational Rules Checker : How to Run DFM RAVEL Rules through GUI ( Video )
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:VideoViewer;src=wp;q=Video/Silicon-Package-Board_Co-Design/vdn/AllegroRRC_RunRAVEL_GUI.html   (in case if you are unable to stream on chrome, use internet explorer to stream this video
