  3. Silk to Solder check in Allegro PCB
  • Subscribers 168
  • Views 14532
ThangapandiCAD
ThangapandiCAD over 9 years ago
Hi All,
Is that possible to check, silk to solder mask overlapping in Allegro itself?
Do we have any constrains or option for that?
  • steve
    steve over 9 years ago
    There's a skill routine that does this for you. Search this forum for autosilk_utils (written by Dave Elder). This is the best method
  • tmd63
    tmd63 over 9 years ago
    Steve, how do you run skill routines? We use a modified version 16.6 here, but I have not been able to get the skills to work.
  • tmd63
    Also, I tried to search autosilk_utils in the whole forum and cannot find the skill file anywhere.
  • steve
    Try http://community.cadence.com/cadence_technology_forums/f/27/t/31029 The instructions on how to run should be part of the zip file (if I remember correctly) or you can edit your allegro.ilinit file (%HOME%\pcbenv) to autoload it.
  • bgsidug
    bgsidug over 9 years ago
    try electronic.ui3g.com you may find lot of things about pcb
