  3. DXF import menu doesnt open.
  • Views 14238
Usane
Usane over 10 years ago
Hi!
I'm trying to import a dxf file in pcb designer 16.6, but dxf import menu doesnt open. I just installed it on this machine. On an other computer its works fine. Can it be solved somehow, or i should try to reinstall it?
Sanya
  • steve
    steve over 10 years ago
    Try deleting your pcbenv folder first (located in %HOME% which is normally C:\SPB_data) then restart the tools. If that doesn't help then try and install the latest hotfix available from Cadence Online Support or your local channel partner who you bought the software from.
  • Usane
    After deleted the pcbenv folder works fine. Thank you wery much.
