  3. Problems creating a mirror image of a documentation frame...
  • Subscribers 167
  • Views 15305
Problems creating a mirror image of a documentation frame around a PCB.
likeabletom
likeabletom over 9 years ago
Hi all,
I have a problem with mirroring and Lines.
I have documentation frame (text + lines) around my board composed of Text and Lines.  I am trying to make a mirror image of the frame so I can document the bottom layer (which is already in mirror image ref des, text on PCB, etc).
I have successfully mirrored the text as a page (text that was on the RHS of the page is now on the LHS of the page), but I am completely failing when it comes to the Lines.  I can get each individual line to mirror separately, but cannot get the Lines to mirror as a group.
How can I either a) mirror the Lines as an entire page, or b) mirror both the Text and Lines as one page in one go.
The mirror option is available for CLines, but not Lines...
Using 16.6.
Robert.
  • redwire
    redwire over 9 years ago
    Try File->Export->IPF
    then File->Import->IPF and choose the correct active class, subclass, and mirror checkbox
  • steve
    steve over 9 years ago
    You could make a Format Symbol of your documentation frame and then place it as a symbol twice the second time right click - mirror. The key here though is to make sure the symbol is drawn on a new subclass layer Drawing Format - Outline_Top. Then when you place the mirrored version PCB Editor automatically creates a new subclass Outline_Bottom.
  • likeabletom
    Perfect!
    Everything that was visible was sucked into the .IPF file and spat back out again.  Mirror did what is said on the box.
    Only thing to watch out for is that it dumps it on an unexpected layer (not a problem).
    It is also an interesting way to turn what is visible (well, most of it) and decompose it down into a bunch of lines (dumb data).
    R.
  • Lock2002
    Lock2002 over 9 years ago
    You could have also selected move and set your point to "User pick" and once you selected everything you wanted mirrored, right click and "mirror geometry" it would have done what you wanted.
  • redwire
    Just curious if it still went to the wrong layer even after selecting the correct class/subclass in the options window?
