  3. Price of bulk production of circuit board
  • Subscribers 168
  • Views 15058
frostfat
frostfat over 9 years ago
Hi guys,
Not your average question, but an easy one. I have no experience with developing PCBs, but I want to look into the possibility of mass producing a circuit board.
Can someone please give me an estimation of the price per unit, for mass producing around (10,000 units) a board with:
GPS component, sim card reader (and the ability to connect to a mobile network), ultrasonic distance sensor, small solar panel and a battery (making the product self sustaining).
Any guesstimates would be really appreciated!
Thanks for your time,
Rob
  • redwire
    redwire over 9 years ago
    Well, it depends...
    1) How many layers
    2) Copper weight
    3) Material type
    4) Finish type
    5) Drill hole count
    6) Special features
    However, given all that, I have paid in high volume ~25c/square inch for a four layer, HASL finish, FR4 board from China and half that for a 2 layer board (1/2 oz outer layers)
  • frostfat
    1) probably two layers 2) no idea 3) whatever you think would suit (the device resides outside) 4) same answer as to 3 5) however many you feel is appropriate for a board of this style 6) N/A. Is the 25c/square inch including price for the components? Thanks for your answer
  • redwire
    25c/in is for raw finished PWB only.
    Finished PWA in high enough volume is about 20-25% more than BOM price.  Not sure if you mean the same high-volume as I do.
    If low volume like <2,000 pcs/mo you will pay a per-item install plus setups that average-up the percentage.  It's best to get with the overseas supplier for more exact pricing.
  • tmd63
    tmd63 over 9 years ago
    You could try http://www.pcbcart.com/quote .
    There you can enter the details of your design and they will provide the price per unit or total as required. It is a simple system to operate as long as you can fill out all the field, it is normally accurate too.
    Or https://www.pcb-pool.com
  • docb
    docb over 9 years ago
    You are asking for total price of a lot of components and design. Much too hard to quickly give you an idea.
