  3. CDS_A0_1 AnalogOutput and SigXplorer?
  • Subscribers 163
  • Views 14356
archive over 10 years ago
Hello
I would like to know how to use the CDS_A0_1 AnalogOutput model from the SigXplorer library but there is no associated topology part to add in the canvas. Where can I find an example?
Regards
  • oldmouldy
    oldmouldy over 10 years ago
    You can just place a single ended output in the canvas and change the bufferModel property to use the Analog output model that you have defined.
    Thanks oldmouldly for your response. I tried your suggestion but doesn't work. For example, by selecting in the canvas the element tdr_out and changing the bufferModel property. It pops up an error message as: PinTerminals for "CDS_AO_1" is incorrect for a IbisOutput part (and I have only available IbisOutputs in my installation).
  • tltoth
    tltoth over 10 years ago
    I've tried to add the CDS_AO_1 to a Single Ended Output and received an error message "PinTerminalsMap for "CDS_AO_1" is incorrect for a IbisOutput part"
    The help file defines how an AnalogOutput model type should look like and gives a model example, but forgot to mention which element in the canvas this model type can be associated to.
    The AnalogOutput type requires 4 terminal device. The IOCell has five terminals.
    How can we create a new symbol for this model in signal explorer?
