  3. Create custom VAC-Source in pspice
  • Subscribers 163
  • Views 18894
komase
komase over 10 years ago
Hi, I'm a beginner in pspice.
I have a bad signal that I could measure and put into an excel table. I want to create a filter and watch the reaction of the bad signal to it. How can i generate a custom source from a signal i measure?
How can I define my own source from a data-file - e.g. excel.
thanks
  • tltoth
    tltoth over 10 years ago
    You can create text file driven voltage or current file source for transient analysis only.
    Put your time and voltage data pairs in a text file and then place a vpwl_file component from the source library on the schematic.
    Setup your FILE parameter to point your full path of data file and simulate.
  • komase
    Hi tltoth
    Thank you very much for this helpful information.
    I found a youtube-video that explains it as well.... - after your hint to the vpwl_file source component.
    Thanks!!!
