  3. cis database configuration error
  • Subscribers 166
  • Views 15319
wecan
wecan over 9 years ago
hi
          I m configured cis database ,after the place the schematic symbol from cis configured database getting the error message for  "PLACE COMPONENT OPERATION FAILED"  why this error message will came, after placed symbol there is no database in that symbol related.
Please give the solutions
  • mkke
    mkke over 9 years ago
    I have same issue when I started Part Management
    Is it a configuration error or ??
  • steve
    steve over 9 years ago
    It could be several things, check the capture.ini file (normally %HOME%\cdssetup\OrCAD_Capture\17.2.0\ (or the release you are running) and make sure your paths to schematic symbols and PCB Footprints are defined correctly. There's an app note:- orcad.co.uk/.../Making_Footprints_Visible_in_Capture.pdf that will go through this. If this is OK I'd also check the CIS Configuration for settings like Transfer to Design and make sure these are all valid.
