  3. .bxl file importing
  • Views 16808
.bxl file importing
tmd63
tmd63 over 10 years ago
There are a number of manufacturers who are using the .bxl file format to specify the footprint.
Is there any reliable methods apart from using the UltraLibrarian software to import .bxl into .dra format.
  • steve
    steve over 10 years ago
    No - The bxl format is proprietary to Ultra Librarian. Most issues I see with this are related to the blank_drawing.dra file located in C:\UltraLibrarian\CadInfos\Allegro15.2 or wherever you have it installed. Normally open this and edit the Drawing Extents and 0,0 location to give the symbol plently of room to generate. The save and run the supplied scripts.
