  3. can't find java to run javaw error message
  • Views 1315
tdr19
tdr19 over 9 years ago
When  i  start up circuit space 4.2 running on allegro 16.5  i get this java error.
E can't find java to run javaw . where does this java reside? in the ema folder?
Tom
  • oldmouldy
    oldmouldy over 9 years ago
    Sounds like you need the Oracle Java Runtime Environment (JRE), a quick web search will get you to the downloadable resources fro installation, otherwise you will need to contact EMA to resolve the issue.
  • tdr19
    Thank you! I will check out the Java site.
    -Tom
