  3. PCB design of Si114x Gesture Control(SI1140DK Development...
  • Subscribers 166
  • Views 508
PCB design of Si114x Gesture Control(SI1140DK Development Kit)
kapp
kapp over 9 years ago
Hi All,
I want to make the PCB of SI114x Gesture control. In the datasheet circuit is given . But In the circuit LEDs are used. The Part no. of that LED is SFH4056. But I have a doubt which LED that I am going to chose in ORCAD library.
I am new in schematic design. Can somebody suggest me ?
Thanks in advance.
  • steve
    steve over 9 years ago
    The datasheet shows this as a 2 pin LED so the default LED symbol in the discretes library is probably good enough. The key part here is the PCB Footprint which won't be there by default so you will need to create it. There are videos showing Padstack and footprint creation. Take a look at:- https://www.youtube.com/watch?v=nqbZKkcvmOk and https://www.youtube.com/watch?v=wfCM0Ho8IE0.
